truefan34
Oct 16, 2017Tutor
difference between connecting 5 ghz wifi on orbi vs ethernet connection to satellite?
Is there an advantage? Connecting by ethernet to the satellite, does that yield better speed/lower latency than connecting just to the 5gz wifi broadcasted?
st_shaw
Oct 18, 2017Master
I get about 100 Mbps more throughput (575 versus 475) wired to the satellite versus connecting to the 5 GHz WiFi. If you can connect with a wire it would be better, because as DarrenM indicated, you are not using another WiFi connection and that saves RF airtime for other wireless devices.
