Jbgutter
Aug 28, 2020Follower
Difference between Orbi RBR 50 and Orbi WiFi 6?
What is the difference between the Orbi RBR50 and the Orbi WiFi 6? Would I get better connectivity and/or speed if I upgrade?
Aug 28, 2020Guru - Experienced User
Be sure to check out the Orbi AX Forum for additional help and information on Orbi AX systems:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
