maaky4
Dec 10, 2018Aspirant
Difference between RBK22 and RBK40
Hi,
I'm looking to buy my first mesh system and I'm stuck for choice. Upon checking specifications for the RBK22 and RBK40, I could only find difference in the gigabit port availabilty. Any other p...
michaelkenward
Dec 11, 2018Guru - Experienced User
Have you tried comparing the data sheets?
There is support stuff for the RBK40 at the end of this link:
>>>> Orbi RBK40 | WiFi System | NETGEAR Support <<<<
Support for the RBK22 is here:
>>> RBK22 | Product | Support | NETGEAR <<<
- maaky4Dec 11, 2018Aspirant
Thanks for the info.
I did take a look at those, and didn't find anything different except for the ports. However, while talking to a customer representative, I was told that the RBK40 is superior in performace in comparison to the RBK20.Really not sure how to go about it.
- FURRYe38Dec 11, 2018Guru - Experienced User
I would recommend going with your home size needs as well. Most routers cover up to about 1100-1500 sq feet by themselves. I have a 5000sq ft home and use a 40 series system in place. Router at one end of the home up stairs and just 1 satellite at the opposite end 40 feet away. I have great coverage and performances for my home.
https://www.netgear.com/orbi/wifi-systems.aspx
- michaelkenwardDec 11, 2018Guru - Experienced User
Not much actually.
I've found the RBK22 for $180 and the RBK40 for $230.
It makes sense paying more if the latter is superior in terms of performance. Looks like the RBK22 is a newer model.
I'm surprised that Netgear Support couldn't provide me a precise answer for this issue.
