JPMARS
Aug 21, 2018Follower
Differences between Orbi routers
 Would anyone be a ble to tell me the exact differences between the Orbi router model RBR40 and model RBR20? I'm trying to decide about the Orbi WiFi System (RBK20W) AC2200 and model Orbi WiFi System ...
Aug 21, 2018Guru - Experienced User
You can see the differences here:
https://wikidevi.com/wiki/Netgear_Orbi_Router_(RBR40)
https://wikidevi.com/wiki/Netgear_Orbi_Router_(RBR20)
One difference is that the RBR20 only has one LAN port.
- PaPaTheGManSep 10, 2018AspirantI'm also interested and confused about the differences. The WikiDevi pages linked do not contain any data. On the spec page, it appears the RBR20 has multiple backhauls, or is that just a repeat of the main antennas? - FURRYe38Sep 10, 2018Guru - Experienced UserCheck specs here: https://www.netgear.com/support/product/orbi.aspx All Home Orbi systems support wired back haul for ethernet connected satellites. Recommend using non managed switches with Orbi systems if needed.
- Blanca_OSep 16, 2018NETGEAR Employee RetiredHi PaPaTheGMan, Please click this link https://www.netgear.com/orbi/ and look for the "Find your Orbi" section. It will help you find the system that suits your need (distance, number of devices and speed). Regards,
 Blanca
 Community Team
