ChrisCox1952
Apr 01, 2024Guide
Differences in speed in 2 tests done directly after eachother
 I am getting strage results when testing internet connection. Testing first time shows download around 200, upload 50  second check directly after first one shows down 500 and up 50. ( second test is...
- Apr 01, 2024When the Orbi 'app' reports Speed Test results, the actual test is performed on the Orbi router and the results are passed to the app for display. Thus, it does not matter how WiFi devices are connected to the system. Ookla Speed Test (their app or their web site) performed on a device are reporting the speed to the actual device.
Apr 01, 2024Guru - Experienced User
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. what method of speedtesting are you using? (app, website, what device, what band are you connected to while testing, how close/far from the router are you)
5. the wired speed should be the most consistent. Do you get the variable speeds hardwired into the modem/gateway?
ChrisCox1952
Apr 01, 2024Guide
Hi Guru
following to your questions
1. Router RBK 53 with 2 stations connected to it
2. Software 2.7.4.24
3. Modem Sagemcom
4. i use speedtest available in Orbi app on my iphone 14 Pro or Ipad Pro 2020, i donot know to which band i am connected, distance to router station about 2 meters.
5. i get same result if i mease speed on my pc which is cabled, Windows 11
regards
Chris
- CrimpOnApr 01, 2024Guru - Experienced UserWhen the Orbi 'app' reports Speed Test results, the actual test is performed on the Orbi router and the results are passed to the app for display. Thus, it does not matter how WiFi devices are connected to the system. Ookla Speed Test (their app or their web site) performed on a device are reporting the speed to the actual device.
- plemansApr 01, 2024Guru - Experienced User
 ChrisCox1952 wrote:
 Hi Guru following to your questions 1. Router RBK 53 with 2 stations connected to it---Thanks! 2. Software 2.7.4.24------There's a newer 2.7.5.4. doubt it'll make any speed difference but always an option. 3. Modem Sagemcom---Most of the Sagemcom's I know of are modem/router combo device. It causes a double nat and the sagemcom might have its own qos built in. Do you have it in passthrough mode? If so, try putting the sagemcom back in router mode (disable its wifi) and the orbi in access point mode. 4. i use speedtest available in Orbi app on my iphone 14 Pro or Ipad Pro 2020, i donot know to which band i am connected, distance to router station about 2 meters.----That'd be hosted on the router. Not on the device you're testing with. Try the actual speedtest app. 5. i get same result if i mease speed on my pc which is cabled, Windows 11---if you're using the orbi app, thats why the testing is the same. regards Chris
