ChrisCox1952
Apr 01, 2024Guide
Differences in speed in 2 tests done directly after eachother
 I am getting strage results when testing internet connection. Testing first time shows download around 200, upload 50  second check directly after first one shows down 500 and up 50. ( second test is...
- Apr 01, 2024When the Orbi 'app' reports Speed Test results, the actual test is performed on the Orbi router and the results are passed to the app for display. Thus, it does not matter how WiFi devices are connected to the system. Ookla Speed Test (their app or their web site) performed on a device are reporting the speed to the actual device.
ChrisCox1952
Apr 01, 2024Guide
Hi Guru
following to your questions
1. Router RBK 53 with 2 stations connected to it
2. Software 2.7.4.24
3. Modem Sagemcom
4. i use speedtest available in Orbi app on my iphone 14 Pro or Ipad Pro 2020, i donot know to which band i am connected, distance to router station about 2 meters.
5. i get same result if i mease speed on my pc which is cabled, Windows 11
regards
Chris
CrimpOn
Apr 01, 2024Guru - Experienced User
