ronothan
Jul 20, 2019Tutor
Different SSID
Would love love some help with setup I have a router which is used for one business and has the SSID “business-wifi”. This modem/router connects directly to the internet. I’d like to set up the ...
Jul 21, 2019Guru - Experienced User
Please post about this over on the main Orbi forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
You would probably run the Orib system in AP mode:
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
No the RBS have to be connected to the back of the RBR or RBR via a ethernet switch connected to the back of the RBR an the RBS connected to this LAN switch.
I’d like to set up the Orbi via wired backhaul to the business-wifi router, with a different SSID called airbnb-wifi
How would I set that up?
And also, can I have the satellites connect to the business-wifi via wired backhaul without a problem!?
- Fl1ntstoneJul 23, 2019Apprentice
Hi,
Normally the Orbi system uses the same SSID for the 2.4Ghz and 5Ghz bands, but you can split them so that they are using different SSIDs. I believe that is what you are trying to do?
CheerZ
