kminor7
Jan 23, 2021Aspirant
Direct connection to Orbi very high, WiFi download speed slow
Hi, I used to get 230+M downloads and 11M upload via WiFi connected devices. Because I upgraded my internet to Gigabyte service, I replaced my Motorola modem to a Netgear CM1200. When I...
vajim
Jan 23, 2021Master
wifi is always going to be slower than a direct connect
you may want to do a search in this forum for there are lots of discussions on the subject.
stand by for zillions of questions
kminor7
I understand WiFi is slower than direct connect. Please read my original post. My wifi download is 25% of what it was before I switched modems. It can't be the modem because both the modem and Orbi unit is getting close to a Gig when directly connected.
The minimum I should be getting is 250+M like I was getting before, but I expected 500-750M if I'm getting a Gig when direct connected.
I believe the R50 is capable of that. I know it's capable of 250+M because I was getting it before. 40M isn't acceptable and must be something that needs to be reset or configuration updated.
- vajimJan 23, 2021Master
did you let your ISP know you have a different modem?
- alokeprasadJan 23, 2021Mentor
Try working your way outwards from the Orbi router.
Shut off all satellites. Power cycle the Orbi router so that it re-acquires the cable modem. After things settle down (the light on the Orbi goes off), be near the router, power cycle your mobile device, let it connect to the Orbi router, and see what wifi speeds you get. Hopefully, your mobile device supports 5 GHz connections and connects using that frequency.
If it is still slow, factory reset the orbi router and try again.
If it is all good, then you know that the router is working as expected. Now, power-on one satellite, let it settle down, be close to it, and test with the mobile device.
You can use the web-interface to the Orbi router and check connection speeds. http://orbilogin.com
one other tip....do a search in this forum on your new modem....lots of chatter
