tbosey
Jan 09, 2019Aspirant
Disable 2.4 GHz radio in AP mode on firmware2.2.1.210
Trying to disable 2.4 GHz radio on Orbi. The option to uncheck "Enable Wireless Router Radio" under Advanced Setup -> Wireless Settings -> Advanced Wireless Settings (2.4GHz b/g/n) is not there as p...
- Jan 09, 2019
Disabling of any radio on the Orbi is not officially support currently on the Orbi.
There a reason you need to do this?
You can try this if you really need to disable radios:
Theres been mixed results...
Jan 09, 2019Guru - Experienced User
