yafai1
Aug 30, 2019Guide
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
Aug 30, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. You can disable the 2.4G SSID broadcast here as well. Though it's only recommended to disable this temporarily and not long term.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
yafai1 wrote:HELLO
2. im finding that devices are not connecting to the closer orbi
3. the setup is confusing
anyhelp will be aprechiated
yafai1
Aug 30, 2019Guide
firmwear is V2.3.5.30
thick walls around 2500sq feet
both connect so far to each other blue light etc
what connection etc i have no idea i cant even change them
lots of wifi nearby (around 10 max)
- FURRYe38Aug 30, 2019Guru - Experienced User
IF you have wifi neighbors, might try setting some manual channels on 2.4Ghz.
If you disable the 2.4G SSID, let us know if this changes anything.
Having thick wall could be a factor as well. What is the distance between the router and satellite(s)?- yafai1Aug 30, 2019Guide
how do i actually disable the ssid? its just one ssid? i dont get it but the speed diffrence is significant
FURRYe38 wrote:IF you have wifi neighbors, might try setting some manual channels on 2.4Ghz.
Having thick wall could be a factor as well. What is the distance between the router and satellite(s)?nothing to do with the satellite its simply the fact that i cant disable the 2.4ghz? its one big network that selects weather your on 5ghz or 2.4ghz if im right (correct me if im wrong)...trying to simple make the whole network 5ghz we dont need the 2.4ghz. 2.4ghz is an issue bevcause lets say im downstairs and the phone is connected to the orbi downstairs 5ghz i go upstaris its still connected to the orbi downstairs just on 2.4ghz?
trying to disable 2.4ghz to force the phone to switch from the main orbi downstairs to upstarirs without turning my phone wifi on and off which usually solves this issue.
know how do i disable 2.4ghz please (step by step instructions)
- Retired_MemberAug 30, 2019
yafai1 wrote:how do i actually disable the ssid? its just one ssid? i dont get it but the speed diffrence is significant
One other item,...when you said..." its just one ssid? i dont get it..."
That's the way a MESH system works. The Orbi takes both the 2.4 & 5G and combines them into one SSID. When it's working properly, the Orbi decides which device connects where.
