yafai1
Aug 30, 2019Guide
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
Retired_Member
Aug 30, 20191. 2.4ghz is enabled and i want to disable it
I understand that this can be done in the settings/advance.....
2. im finding that devices are not connecting to the closer orbi
3. the setup is confusing
The firmware you're currently on has some known issues. -
Was your system working well before the last update?
- yafai1Aug 30, 2019Guide
just bought it 2 hours ago
- Retired_MemberAug 30, 2019
yafai1 wrote:just bought it 2 hours ago
OK....you can try to troubleshoot it, but with the firmware you're running, you're best bet is to try and download/install earlier version. Look for the download section here for your router/sats
