yafai1
Aug 30, 2019Guide
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
Retired_Member
Aug 30, 2019
FURRYe38 wrote:You can disable the 2.4G SSID broadcast by unchecking the "enable 2.4G SSID Broadcast" found under Advanced Tab/Advanced Settings/Wireless Settings.
NICE.
yafai1
Aug 30, 2019Guide
This is tiring. If it was that simple as to just flip a switch I would of have done it. But this **bleep** software is not that user friendly there is no such things as 2.4ghz off/on that mythical switch that you lot are speaking about in the advanced bull **bleep** area just ain't there. If it was I would of have found it long ago which would of have meant that I wouldn't need to post in this community.
Do you lot understand? There is no switch located where you lot have been saying it is. I checked online and there used to be one maybe in a diffrent (older) firmware but today it simply ain't there on the latest firmware and before u say downgrade for the love of god I cant it just upgrades itself. This system is flawed...
- CrimpOnAug 30, 2019Guru - Experienced User
Maybe this is what people are talking about? (the check mark box beside "Enable SSID Broadcast")
- FURRYe38Aug 30, 2019Guru - Experienced User
- yafai1Aug 30, 2019Guide
FURRYe38 wrote:So you not see:
Advanced Wireless Settings (2.4GHz b/g/n)
Enable SSID Broadcast <check box
that does not do anything? i have a device that only connects to 2.4ghz and it still connects to the wifi network? plus both 2.4ghz and 5ghz and under the same name as in i think they are merged?
Devices are funny about "Hidden Networks". I may be mistaken, but what I remember is sometimes the device has to be told to "forget" a network.
- CrimpOnAug 31, 2019Guru - Experienced User
yafai1 wrote:
that does not do anything? i have a device that only connects to 2.4ghz and it still connects to the wifi network? plus both 2.4ghz and 5ghz and under the same name as in i think they are merged?To recap: (a) unchecking the "Enable SSID Broadcast" for 2.4G network, (b) clicking "Appply", (c) telling a 2.4G only device to "forget" the Orbi SSID, and (d) restarting the device.... and the device reconnects to the Orbi anyway?
