yafai1
Aug 30, 2019Guide
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
Aug 30, 2019Guru - Experienced User
yafai1
Aug 30, 2019Guide
FURRYe38 wrote:So you not see:
Advanced Wireless Settings (2.4GHz b/g/n)
Enable SSID Broadcast <check box
that does not do anything? i have a device that only connects to 2.4ghz and it still connects to the wifi network? plus both 2.4ghz and 5ghz and under the same name as in i think they are merged?
- CrimpOnAug 30, 2019Guru - Experienced User
Devices are funny about "Hidden Networks". I may be mistaken, but what I remember is sometimes the device has to be told to "forget" a network.
yafai1 wrote:
that does not do anything? i have a device that only connects to 2.4ghz and it still connects to the wifi network? plus both 2.4ghz and 5ghz and under the same name as in i think they are merged?To recap: (a) unchecking the "Enable SSID Broadcast" for 2.4G network, (b) clicking "Appply", (c) telling a 2.4G only device to "forget" the Orbi SSID, and (d) restarting the device.... and the device reconnects to the Orbi anyway?
