yafai1
Aug 30, 2019Guide
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
yafai1
Aug 30, 2019Guide
Well smart arse it's in this thread read the **bleep**ing thing before u turn all smart on us. Tired of the same old dumb replies.
Retired_Member
Aug 30, 2019
2. im finding that devices are not connecting to the closer orbi .
If this is your reason.....it's NOT. How devices connect is all about how the Orbi and the Mesh system works. What's wrong with that? If you're worried about SPEED, you're chasing rabbits.
OBTW....we're all adults here. You can use civil and respectable language. Thanks
- BoilerPlateAug 31, 2019Apprenticevaj you should practice what you preach!!!
- Retired_MemberAug 31, 2019
BoilerPlate wrote:
vajyou should practice what you preach!!!How so?
