yafai1
Aug 30, 2019Guide
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
PittsSC1
Sep 10, 2019Initiate
:smileyhappy:One might want do disable 2.4 GHz so they simply always use 5 GHz. :smileyhappy: Is not that reason enough?
CrimpOn
Sep 10, 2019Guru - Experienced User
PittsSC1 wrote:One might want do disable 2.4 GHz so they simply always use 5 GHz.: Is not that reason enough?
Of course it's a good reason. Someone might want (a) to be unable to connect any of the "Internet of Things" devices that only support 2.4G, (b) to have their WiFi signal drop out when they wander too far for 5G to penetrate while 2.4G would keep them on-line. Netgear could have made discussions like this unnecessary if they had simply added a check box, "Turn off radio" for each band. :smileylol:
