yafai1
Aug 30, 2019Tutor
disable 2.4ghz on orbi
HELLO latest softwear 2 orbs less than 30 feet apart signal strength good etc. slight issues with the orbi currently, 1. 2.4ghz is enabled and i want to disable it 2. im finding that dev...
PittsSC1
Sep 10, 2019Initiate
:smileyhappy:One might want do disable 2.4 GHz so they simply always use 5 GHz. :smileyhappy: Is not that reason enough?
Tucsonbroker
Sep 11, 2019Initiate
You can’t disable the 2.4 radio but you could rename the 5G band to something else. Then have your devices forget the 2.4G info and login into the 5G. The instructions are here on the forum, telnet into the router it’s pretty simple to do.
