RichieRich1891
May 27, 2021Follower
Disable 2.4GHz radio on Orbi RBK20
Hello, does someone know if I disable my 2.4 GHz radio, it will be disabled for my private SSID and my Guest SSID? I'm using the netgear Orbi RBK20 (RBR20 + RBS20). Kind regards, Richie
CrimpOn
May 27, 2021Guru - Experienced User
RichieRich1891 wrote:Hello, does someone know if I disable my 2.4 GHz radio, it will be disabled for my private SSID and my Guest SSID?
If you are using a telnet hack to actually turn off the radio, then "off means off".
If you are using the procedure of unchecking the Advanced Wireless Setup box "Enable SSID" for 2.4G, that should disable only the primary SSID broadcast. To disable broadcasting the Guest SSID, disable Guest access.
I agree with FURRYe38 that this will make an interesting experiment.
