lgrip
Sep 21, 2018Aspirant
Disable 5 GHz Oribi RBR53
Model RBK53 Orbi Router with 2 satellites, Firmware V2.1.4.16 with a computer running Windows 10. I have a RBK53 Orbi router. I have a new device which I need to connect to the router. The new devic...
michaelkenward
Sep 22, 2018Guru - Experienced User
There is a manual for the Orbi WiFi System somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
lgrip wrote:
The new device will only concect on 2.4GHz band. To connect the device I need to disable the 5GHz band. How can I temporaley disable and then reconncet the 5 GHz band.
There should be no need to disable 5 GHz to get something to connect to the 2.4 GHz. If the device can't see 5 GHz, it won't try to connect.
Then again, it might help if you said what that "new device" is and why you think you need to disable 5 GHz.
PS For the benefit of anyone else trying ti help, there is an error in the subject, RBR53 should be RBK53, as it says in the text.
- ARFSep 22, 2018Aspirant
I haven’t found a way to turn off the 5ghz but one work around is to login to Orbi and change the transit power of 5ghz down to 25% while you setup new device.
