lgrip
Sep 21, 2018Aspirant
Disable 5 GHz Oribi RBR53
Model RBK53 Orbi Router with 2 satellites, Firmware V2.1.4.16 with a computer running Windows 10. I have a RBK53 Orbi router. I have a new device which I need to connect to the router. The new devic...
ekhalil
Feb 22, 2019Master
ydlazkov wrote:
In the Wireless Settings, what needs to be done to temporarily disable 5GHz?
There is no wireless settings in Orbi to disable a wifi radio band. You need to use telnet to do this. Please follow the following steps to temporarily disable the 5 GHz band:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following command to temporarily disable 5 GHz band:
root@RBR50:/# ip link set down dev $(config get wl5g_NORMAL_AP)
- Do the device settings that you want to do, then enable the 5 GHz band again using the following command:
root@RBR50:/# ip link set up dev $(config get wl5g_NORMAL_AP)
HaveComment
Feb 24, 2019Tutor
MESSING WITH TELNET IS NOT REQUIRED. (Or at least it wasn't for me.)
The solution from this thread worked great for me on an internet camera and robot vacuum: https://community.netgear.com/t5/Orbi/Can-I-Temporarily-Turn-Off-5GHz/m-p/1666642/highlight/false#M45804
Short version: go to Advanced Setup>Wireless Settings>Advanced Wireless Settings (5GHz 802.11a/n/ac)>Transmit Power Control and decrease the 5GHz strength to 25%. Then you can use your phone on 2.4GHz for setup.
- FURRYe38Feb 25, 2019Guru - Experienced User
Does this also work for you?
