Sanden
Mar 01, 2021Tutor
Disable 5GHz
Hi, I an Orbi Tri-Band Mesh WiFi System 3 Gbps model # RBR50V2. One band is 2.4 GHz and the other two bands are 5GHz. I can’t set-up a Netatmo Smart Video Doorbell with my iPhone. The doorbell is ...
Mar 02, 2021Guru - Experienced User
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.
Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Sanden wrote:Hi,
I an Orbi Tri-Band Mesh WiFi System 3 Gbps model # RBR50V2. One band is 2.4 GHz and the other two bands are 5GHz. I can’t set-up a Netatmo Smart Video Doorbell with my iPhone. The doorbell is not compatible with 5GHz networks but only can connect to a 2.4 GHz network. Is it possible to disable the 5GHz bands and only have the 2.4 GHz band active to allow set-up of the video doorbell? If video doorbell can be added, how to I disable the 5GHz on my router? Can the 5GHz bands be reactivated once the doorbell is added?
Thank you for your help!
Sanden
Mar 03, 2021Tutor
Hi,
Thank you for your suggestions. When I go to Advanced Wireless Settings I don't see "Broadcast SSID or 5G". I see the following:
Name (SSID)
2.4GHz Channel Auto
5GHz Channel 48
What do you recommend?
