Sanden
Mar 01, 2021Tutor
Disable 5GHz
Hi, I an Orbi Tri-Band Mesh WiFi System 3 Gbps model # RBR50V2. One band is 2.4 GHz and the other two bands are 5GHz. I can’t set-up a Netatmo Smart Video Doorbell with my iPhone. The doorbell is ...
Mar 17, 2021Guru - Experienced User
Ya that should have worked. Try the RBRs web page ERASE function and see. I'd disconnect the WAN port from the RBR from the modem and all other wired devices from the RBR accept for 1 wired PC.
The ERASE should clear out everything and if you clear your browser caches as well, then reenter 192.168.1.1, you should see a web page letting you know to use the Orbi app to set up the router or down at the very bottom select this link if you don't want to use Orbi app.
cbell4444
Mar 18, 2021Star
Will try it this afternoon...
