stevefxp's avatar
stevefxp
Apprentice
Apr 30, 2019
Disable 802.1b?
Hello all,
If I do not have any 802.1b devices how can I disable this support in the Orbi?
Thanks,
Steve
  • You can't. modes are automatic with Smart Connect and MESH systems. If you don't have any B mode devices then the router probably wont use any resources for it. Nothing to worry about.
1 Reply
  • FURRYe38's avatar
