garrettg84
Jan 31, 2019Guide
Disable auto change IP address
I've seen similar posts about a way to disable the auto change IP address before. They've been brushed off. The 'answers' and 'solutions' are wrong. There is an issue with the product. Every month wh...
garrettg84
Feb 01, 2019Guide
Chuck_M wrote:
In an earlier post, we talked about a tracert test to demonstrate where the public and private IP addresses started and stopped... that may be useful here.
Can you try and tracert a site, say microsoft.com and post the results here? It may show that double NAT condition.
Yes, let's assume I've got no idea what I'm talking about. Here's your traceroute. No, there is no double NAT.
tracert google.com
Tracing route to google.com [172.217.5.238]
over a maximum of 30 hops:
1 4 ms 3 ms 3 ms 10.99.99.1
2 20 ms 17 ms 19 ms cpe-45-37-XX-X.nc.res.rr.com [45.37.XX.X]
3 23 ms 18 ms 12 ms 174.111.103.224
4 16 ms 17 ms 14 ms cpe-024-025-062-000.ec.res.rr.com [24.25.62.0]
5 17 ms 22 ms 19 ms be31.drhmncev01r.southeast.rr.com [24.93.64.184]
6 32 ms 22 ms 31 ms 66.109.10.176
7 50 ms 30 ms 46 ms 66.109.5.117
8 22 ms 13 ms 27 ms ix-ae-17-0.tcore1.aeq-ashburn.as6453.net [66.198.154.21]
9 27 ms 24 ms 20 ms 72.14.211.36
10 25 ms 22 ms 25 ms 108.170.240.97
11 20 ms 22 ms 19 ms 216.239.54.125
12 19 ms 22 ms 20 ms iad30s07-in-f238.1e100.net [172.217.5.238]
Please, read my actual posts. I get a private IP while the cable modem is connecting. This IP is 192.168.100.0/24. That does not conflict with my Orbi internal network of 10.99.99.0/24. Orbi still loses its mind every month when my cable modem resets and grabs a new IP. The RFC 1918 address is assigned - again, always 192.168.100.0/24 and never conflicting with 10.99.99.0/24. After that, the link is dropped and brought back up and the Orbi is *OFFERED* a public non-RFC 1918 address which it does not take. Still, Orbi loses its mind.
Eventually it appears the Orbi itself goes into bridge mode and I end up with a public IP in the 45.36.x.x-45.37.x.x range on the INSIDE OF MY NETWORK. This means only a single device in my house among a hundred or so devices gets to use the internet. Nothing else gets an IP because my ISP only allows a single public IP.
This is even more confusing because the Orbi still sits flipping between RFC 1918 addresses as if it is detecting a conflict while in bridge mode.
Often times I have to unplug the Orbi from the cable modem and reset the Orbi router to get it to stop flipping IPs. After that, it still comes up one last time with the IP conflict detection page, then I'm able to change it because it stopped running from imaginary conflicts.
No, I won't take a picture of my cabling. There are no devices besides the cable modem plugged into the Orbi (this is the purpose of wireless mesh, no?). Yes, it is in the correct yellow internet port.
ekhalil
Feb 01, 2019Master
garrettg84 wrote:.................... I get a private IP while the cable modem is connecting. This IP is 192.168.100.0/24. That does not conflict with my Orbi internal network of 10.99.99.0/24. Orbi still loses its mind every month when my cable modem resets and grabs a new IP. The RFC 1918 address is assigned - again, always 192.168.100.0/24 and never conflicting with 10.99.99.0/24. After that, the link is dropped and brought back up and the Orbi is *OFFERED* a public non-RFC 1918 address which it does not take. Still, Orbi loses its mind.
Seems that Orbi gets confused by the ISP modem changing the IP address from public to private and then public again.
One thing that can help here is the DNS settings, what DNS do you have set in the Internet Settings?
- garrettg84Feb 01, 2019Guide
DNS is set statically in the Orbi to google's dns servers. The cable modem provides no ability to statically assign addresses as all administrative features are disabled from my view.
- ekhalilFeb 01, 2019Master
Can the ISP router provide DNS? Have you tried to set the modem IP address as the DNS in Orbi?
I don't want the ISP DNS. I'm on Spectrum/Charter networks. Their DNS servers don't work half the time (regular timeouts). The other half the time they manipulate DNS and try to slipstream their own advertisements.
In the interest of not redirecting this thread, let me make this abundantly clear. I don't care about DNS. DNS is not the issue. DNS has nothing to do with detecting IP address conflicts. It is a bit of a red herring. The issue is IP address conflicts and some ridiculous nanny service on the Orbi that goes wonky and kills my connectivity every time my cable modem resets.
