garrettg84
Jan 31, 2019Guide
Disable auto change IP address
I've seen similar posts about a way to disable the auto change IP address before. They've been brushed off. The 'answers' and 'solutions' are wrong. There is an issue with the product. Every month wh...
ekhalil
Feb 02, 2019Master
I agree,
garrettg84, I think that you can easily solve your issue by keeping the private address on the ISP modem so the interface to Orbi keeps always a private address..
Using bridge (passthrough) in the modem seems not working for you since the modem will -momentarily- change to private address when it looses the internet connection and then gets back the public IP address which confuses Orbi.
If you have access to your modem (or if the ISP can help you with that) then I suggest to remove the passthrough mode and instead use DMZ forwarding. This way the modem will keep the private address network and the DMZ forwarding will take care of the double NAT.
garrettg84
Feb 02, 2019Guide
ekhalil wrote:
I agree,
I don't have the ability to control inbound ports because the ISP modem is locked down. This is not a solution. I don't need to dumb down my network and configurability because the Orbi is falsely detecting an IP conflict. I will simply get another vendor's product that does not have these rediculous issues in a feature I don't want or need.
- michaelkenwardFeb 02, 2019Guru - Experienced User
A word of warning, all routers are likely to show similar behaviour if you insist on slapping them behind another router.
By the way, a quick check of a manual for the Ubee DDW36C suggests that it has advice on setting it up in bridge mode.
Ubee DDW36C Advanced Wireless Gateway - cloudfront.net
You may need those instructions with the next router you try to shoehorn on to your network.
- garrettg84Feb 02, 2019Guide
I guess nobody reads any of the above posts before posting. I have no control over my cable modem. I have to call my ISP to get them to put it in 'pass through' (Bridge mode). I don't need to, nor can I, configure my cable modem.
I need the Orbi to kill the IP conflict service. It is not functioning properly. My internal network subnet is 10.99.99.0/24. The external subnet is either a public IP address during normal operation, or 192.168.100.0/24 during connecting/reset operations. There is never an actual conflict. These subnets do not overlap. There is a problem with the service.I don't have a router slapped behind a router. Stop being inflamitory. Read the posts. Offer something useful, or simply don't comment. It is very easy.
- CrimpOnFeb 02, 2019Guru - Experienced User
Which page of the ubee manual offers advice? The Advanced->Options page states that once put in Bridged Mode, all of the other menu items can be seen but are not active. The advice must be on another page? I am considering putting my ubee into Bridge Mode, and this discussion has made me reluctant to try it.
If you don't need it for any particular reason, don't do it or you'll likely end up in my same condition every single month with no connectivity until you can chase down the constantly moving Orbi.
I must have mine in bridge mode otherwise I cannot allow inbound ports as necessary because I don't have access to any configuration pages in my modem.
