garrettg84
Jan 31, 2019Guide
Disable auto change IP address
I've seen similar posts about a way to disable the auto change IP address before. They've been brushed off. The 'answers' and 'solutions' are wrong. There is an issue with the product. Every month wh...
garrettg84
Feb 02, 2019Guide
ekhalil wrote:
I agree,
garrettg84, I think that you can easily solve your issue by keeping the private address on the ISP modem so the interface to Orbi keeps always a private address..
Using bridge (passthrough) in the modem seems not working for you since the modem will -momentarily- change to private address when it looses the internet connection and then gets back the public IP address which confuses Orbi.
If you have access to your modem (or if the ISP can help you with that) then I suggest to remove the passthrough mode and instead use DMZ forwarding. This way the modem will keep the private address network and the DMZ forwarding will take care of the double NAT.
I don't have the ability to control inbound ports because the ISP modem is locked down. This is not a solution. I don't need to dumb down my network and configurability because the Orbi is falsely detecting an IP conflict. I will simply get another vendor's product that does not have these rediculous issues in a feature I don't want or need.
michaelkenward
Feb 02, 2019Guru - Experienced User
A word of warning, all routers are likely to show similar behaviour if you insist on slapping them behind another router.
By the way, a quick check of a manual for the Ubee DDW36C suggests that it has advice on setting it up in bridge mode.
Ubee DDW36C Advanced Wireless Gateway - cloudfront.net
You may need those instructions with the next router you try to shoehorn on to your network.
- garrettg84Feb 02, 2019Guide
I guess nobody reads any of the above posts before posting. I have no control over my cable modem. I have to call my ISP to get them to put it in 'pass through' (Bridge mode). I don't need to, nor can I, configure my cable modem.
I need the Orbi to kill the IP conflict service. It is not functioning properly. My internal network subnet is 10.99.99.0/24. The external subnet is either a public IP address during normal operation, or 192.168.100.0/24 during connecting/reset operations. There is never an actual conflict. These subnets do not overlap. There is a problem with the service.I don't have a router slapped behind a router. Stop being inflamitory. Read the posts. Offer something useful, or simply don't comment. It is very easy.
- CrimpOnFeb 02, 2019Guru - Experienced User
Which page of the ubee manual offers advice? The Advanced->Options page states that once put in Bridged Mode, all of the other menu items can be seen but are not active. The advice must be on another page? I am considering putting my ubee into Bridge Mode, and this discussion has made me reluctant to try it.
If you don't need it for any particular reason, don't do it or you'll likely end up in my same condition every single month with no connectivity until you can chase down the constantly moving Orbi.
I must have mine in bridge mode otherwise I cannot allow inbound ports as necessary because I don't have access to any configuration pages in my modem.
Have you done a "total factory reset" on the Orbi?
When I was having issues with the Orbi log not working correctly, I resisted doing a "total reset" for months (because of the tedium of entering all of the IP's I had assigned to devices. With over 100 items on a network, it would take a problem like yours to get me to do it. Fortunately, ekhalil showed me a way to do a mass import of IP assignments, device names, etc. (https://community.netgear.com/t5/Orbi/Quick-way-to-re-enter-your-IP-reservations-after-factory-reset/m-p/1691698)
The reason I ask about a total restart is these sections in your description:
Eventually it appears the Orbi itself goes into bridge mode and I end up with a public IP in the 45.36.x.x-45.37.x.x range on the INSIDE OF MY NETWORK. This means only a single device in my house among a hundred or so devices gets to use the internet. Nothing else gets an IP because my ISP only allows a single public IP.
Often times I have to unplug the Orbi from the cable modem and reset the Orbi router to get it to stop flipping IPs. After that, it still comes up one last time with the IP conflict detection page, then I'm able to change it because it stopped running from imaginary conflicts.
If the Orbi is going into Bridge Mode or changing its own LAN side address from 10.99.99.1, then something is VERY WRONG.
- FURRYe38Feb 02, 2019Guru - Experienced User
So do you see this IP address conflic with your modem and the Orbi?
I have no issues because my ubee cable modem is acting as a router. No matter what happens on the cable side, the modem always shows 192.168.0.1 on its LAN side and assigns my Orbi 192.168.0.3. I have left my Orbi in the default mode of 192.168.1.1 on its LAN side and assigning IP's from the 192.168.1.x range. I also do not have over 100 WiFi devices.
