garrettg84
Jan 31, 2019Guide
Disable auto change IP address
I've seen similar posts about a way to disable the auto change IP address before. They've been brushed off. The 'answers' and 'solutions' are wrong. There is an issue with the product. Every month wh...
jbofjax
Feb 19, 2019Tutor
The typical suggestion so far is to turn my expensive router into a dumb WiFi system! The suggested “fix” is to put my Orbi in AP mode.
Feb 20, 2019Guru - Experienced User
It would be also something to ask your ISP to change out your modem router combo for a modem with out a router as well. This would fix your issue. Then you can run the Orbi in router mode.
