techc0de
Sep 02, 2021Aspirant
Disable auto update on Orbi RBK50 ?
Hello all, I had read many threads and tried out several methods suggested by the community to disable the auto update on my Orbi RBK50. The currently firmware is v2.7.3.22, and I tried rolled it b...
Sep 02, 2021Guru - Experienced User
It will work if it doesn't have the IP pass thru, you'll be in a double NAT condition. You may or may not see issues with certain apps or online services. If your a gamer then you may see more issues while in double NAT.
You can configured the RBR for AP mode and use it in AP mode to avoid double NAT issues while blocking those URLs.
