techc0de
Sep 02, 2021Aspirant
Disable auto update on Orbi RBK50 ?
Hello all, I had read many threads and tried out several methods suggested by the community to disable the auto update on my Orbi RBK50. The currently firmware is v2.7.3.22, and I tried rolled it b...
100won
Sep 23, 2021Star
I scanned some domains' netgear.
http.fw.updates1.netgear.com,
time-e.netgear.com,
e70.g.akamaiedge.net,
netgear.com,
devcom.up.netgear.com,
registration.ngxcld.com,
netgear-devrecog.fing.io
If you use pfsense, you will create alias and create rules on WAN tab then block Router & Satellite IP access Alias. See picture below.
- FURRYe38Sep 23, 2021Guru - Experienced User
Only ones needed are:
- 100wonSep 23, 2021Star
Hi,
I tried to block 2 domains but failed.
So that I scanned some domains which the router and satellite access.
When you go to Advanced - Administration - Firmware Update. The router will access to devcom.up.netgear.com, a1599er83nvyl8.iot.us-west-2.amazonaws.com, www.netgear.com
When using NG's ntp server, it will connect to time-e.netgear.com
The "cached" domain a1599er83nvyl8.iot.us-west-2.amazonaws.com can change anytime they want. That is the reason I list some domains.
If we use pfsense, we can block only .*netgear.com, .*ngxcld.com for all subdomains. And e70.g.akamaiedge.net
I tried to update voxel's firmware, the router access to this domain: netgear-devrecog.fing.io
Add more picture
