techc0de
Sep 02, 2021Aspirant
Disable auto update on Orbi RBK50 ?
Hello all, I had read many threads and tried out several methods suggested by the community to disable the auto update on my Orbi RBK50. The currently firmware is v2.7.3.22, and I tried rolled it b...
100won
Sep 23, 2021Star
Hi,
I tried to block 2 domains but failed.
http.fw.updates1.netgear.com
So that I scanned some domains which the router and satellite access.
When you go to Advanced - Administration - Firmware Update. The router will access to devcom.up.netgear.com, a1599er83nvyl8.iot.us-west-2.amazonaws.com, www.netgear.com
When using NG's ntp server, it will connect to time-e.netgear.com
The "cached" domain a1599er83nvyl8.iot.us-west-2.amazonaws.com can change anytime they want. That is the reason I list some domains.
If we use pfsense, we can block only .*netgear.com, .*ngxcld.com for all subdomains. And e70.g.akamaiedge.net
I tried to update voxel's firmware, the router access to this domain: netgear-devrecog.fing.io
Sep 23, 2021Guru - Experienced User
If you block only those two, then go in and check the FW updates and run a FW Update Check, the status should report "Service Not Available".
Voxels FW won't update anything but his stuff however not sure if he set up auto update for his FW or users just have to manually install FW update. Been a while since I used his FW.
- CrimpOnSep 23, 2021Guru - Experienced User
Voxel's firmware does not auto-update. Manual only.
- 100wonSep 23, 2021Star
Yes, I knew he turned off auto update but I saw the netgear-devrecog.fing.io domain when scanning the Voxel's installed router.
After returning stock firmware, I have not seen that domain anymore.
//Someone try to convert RBR50 to SRR60? :smileylol:
- FURRYe38Sep 24, 2021Guru - Experienced User
Ah no.
