HoopSpin
Dec 04, 2016Aspirant
Disable Beamforming
Forgive the basic question. I've read a number of posts regarding an issue I'm having with the Orbi dropping connection to Nest Cameras. Many have suggested a solution of disabling beamforming, at le...
krf007
Dec 04, 2016Star
Go to the Tab Advanced
Then to Advanced Setup
Then to Wireless Settings
Scroll down - second line from bottom
- HoopSpinDec 04, 2016Aspirant
Thank you for the response.
On this tab, I see three groups:
Advance Wireless Settings (2.4GHz b/g/n)
Advance Wireless Settings (5 GHz 802.11 a/n/ac)
Back haul Password
The second from the bottom is Trasnsmit Power Control under the 5GHz grouping. I don't see a reference to Beamforming on the page. Am I in the right spot?
