OzHomer
Sep 22, 2019Initiate
Disable boradcast SSID
Hi. I am setting up the Orbi RBS20 router (firmware v2.3.5.26) and satellites. I want to hide the network/disable SSID broadcast. On the router login page (www.orbilogon.com; accessed on Mac OS 10.14.6 via Safari v13) ) there is no option under either the BASIC or ADVANCED tabs to enable/disabble SSID (I can only do this for the Guest Network, which I am not setting up). How do I do this for the main wifi network?
Many thanks in advance.
This is on the Advanced Tab->Advanced Settings->Wireless Settings
