Louann
Feb 28, 2021Follower
Disable bridge mode
I'm trying to set up my new Orbi system. I have a Ubee gateway modem/router. When setting up, it keeps saying my ethernet cable isn't connected & it is. I called Netgear & 28 hours later the only ...
Mar 03, 2021Guru - Experienced User
You would need to talk to your ISP and have them help you enusre the modem is bridge fully an no other ISP configurations are needed at the modem or on the RBR router if they require that.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
