tammersalem
Apr 17, 2019Follower
Disable Daisy Chain Mode not working
Hello,
I have an issue with poor connection in my backhaul specifically with an RBW30 add on satellite.
My configuration is as follows:
RBR50 Router
RBS50 Satellite
RBW30 Satellite
Apr 17, 2019Guru - Experienced User
With the RBR at the elbow of the L placement configuration, Daisy Chain will be of no benefit and will not work in this kind of placement configuration. If the RBR was at the head or tail of the L configuration, then maybe DS would work.
Try a factory reset on the RBR and setup from scratch. Ensure DS is disabled before bringing on the RBSs.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
