  • No, the Orbi does not give you that level of control (yet) nor do you likely need to do that. You may 'want' to but I've yet to hear a case where somone 'needs' to.
    • Thank you. Just trying to find a tricky way to get certain cams on 2.4ghz only. It’s currently connecting under 5ghz and signal is weak.
