ryanjohn04
Oct 08, 2017Guide
Disable Guest 5Ghz
Is there a way to disable the Guest Network 5Ghz band?
- aazVirtuoso
No, the Orbi does not give you that level of control (yet) nor do you likely need to do that. You may 'want' to but I've yet to hear a case where somone 'needs' to.
- Thank you. Just trying to find a tricky way to get certain cams on 2.4ghz only. It’s currently connecting under 5ghz and signal is weak.
