madhatter
Mar 10, 2019Apprentice
DISABLE LAN PORTS ON RBS50
I plan on putting the RBS50 (the satellite) in a family room / living room area. Guests would be able to access the internet through Guest-Mode Wireless. I want to prevent guests from being able to...
- Mar 11, 2019
madhatter wrote:
......... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct? .......
Commited configuration changes will be stored in NVRAM and will be restored after system restart, power cycle or upgrade. It will also be stored in backup and can be restored.
Mar 11, 2019Guru - Experienced User
He would also need to enable TELNET as well. TELNET is disabled by default on NG routers. :smileywink: Use of a telnet program suggestion would be good to for someone who hasn't done this before. Putty or TeraTerm are great telnet programs.
ROUTERIPADDRESS\debug.htm
madhatter
Mar 11, 2019Apprentice
Thank you ... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct? Since I will be remote from this router, can I telnet into it remotely if I have remote administration turned on?
- FURRYe38Mar 11, 2019Guru - Experienced User
Possibly, not sure if changed in telnet persist thru a FW update. Definately not thru a factory reset.
- Ragar99Mar 11, 2019Luminary
Or go the physical route and buy a RJ-45 Port Blocker.
- ekhalilMar 11, 2019Master
- madhatterMar 11, 2019Apprentice
Thanks to all for your help on this ... very useful info on how to access the LAN port options. Also helpful was the rj45 port blocker. The combination will work well for me.
