madhatter
Mar 10, 2019Apprentice
DISABLE LAN PORTS ON RBS50
I plan on putting the RBS50 (the satellite) in a family room / living room area. Guests would be able to access the internet through Guest-Mode Wireless. I want to prevent guests from being able to...
- Mar 11, 2019
madhatter wrote:
......... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct? .......
Commited configuration changes will be stored in NVRAM and will be restored after system restart, power cycle or upgrade. It will also be stored in backup and can be restored.
madhatter
Mar 11, 2019Apprentice
Thank you ... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct? Since I will be remote from this router, can I telnet into it remotely if I have remote administration turned on?
ekhalil
Mar 11, 2019Master
- madhatterMar 11, 2019Apprentice
Thanks to all for your help on this ... very useful info on how to access the LAN port options. Also helpful was the rj45 port blocker. The combination will work well for me.
