madhatter
Mar 10, 2019Apprentice
DISABLE LAN PORTS ON RBS50
I plan on putting the RBS50 (the satellite) in a family room / living room area. Guests would be able to access the internet through Guest-Mode Wireless. I want to prevent guests from being able to...
- Mar 11, 2019
madhatter wrote:
......... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct? .......
Commited configuration changes will be stored in NVRAM and will be restored after system restart, power cycle or upgrade. It will also be stored in backup and can be restored.
madhatter
Mar 14, 2019Apprentice
thanks for the idea, the satellite will need to be located in a more open area, though.
Chuck_M
Mar 14, 2019Mentor
For some reason the post above is truncated
- ekhalilMar 14, 2019Master
The post is just the first line, the rest is madhatter 's signature :)
- Chuck_MMar 14, 2019Mentor
I got that, can you read his entire post? At least one line of it is obscured by his signature
- madhatterMar 14, 2019Apprentice
yes, this is/was the post:
Hatter, check out the attachment and look at a screen cap of your post and signature.
