fdanna
May 09, 2019Star
Disable Port Scan and DoS Protection Misleading
Having noticed a slowdown in my internet and frequent lag, I checked my logs only to discover I'm getting DDoS attacks nearly every 15 minutes! They IPs are from all over the world. My first instinct...
ekhalil
May 09, 2019Master
fdanna wrote:
........... My first instinct was to make sure I had disabled ping response on the WAN port, which I had, but it was still pinging! ..........
If you ping from a computer attached to your wifi and ping the WAN port you will get a response. Please test from a computer not attached to Orbi to get correct results.
fdanna wrote:
.........Then come to find out, on Orbi, when you turn on VPN it re-enables ping responses. .......
You can overcome this by doing the following telnet command (it will not impact VPN):
root@RBR50:/# config get wan_endis_rspToPing
You will get the default which is 1 (means Orbi should respond to WAN ping requests)
root@RBR50:/# config set wan_endis_rspToPing=0
root@RBR50:/# config commit
