fdanna
May 09, 2019Star
Disable Port Scan and DoS Protection Misleading
Having noticed a slowdown in my internet and frequent lag, I checked my logs only to discover I'm getting DDoS attacks nearly every 15 minutes! They IPs are from all over the world. My first instinct...
Blanca_O
May 09, 2019NETGEAR Employee Retired
Thank you for sharing this observation and test result. Please allow me to check this further and will get back to you the soonest.
Blanca
Community Team
- go4parJul 05, 2019Aspirant
Two months and no solution?? I am just confused by one issue here. Why is the 'Default' a checked box/enabled "disabled port scan and dos protection? Even the help pop-up on the same router page states it should only be disabled on 'special circumstance'. Thus I have to uncheck the box in order to enable the protection. But, and it's a big but, I do get the same dos attacks on an apple ipad every few minutes. My PC gets them also but it is the Router's DNS (75.75.75.75) attacking the IP/Mask. (??) This does seem to stop when I leave the box checked, disabling scans and protection. Doesn't make sense.
Also, neither Comcast nor Net Gear say they can adjust my modem/router clock and thus one hour behind. I don't see any clock settings incl. DLSavings time.
A little help pls..- CrimpOnJul 05, 2019Guru - Experienced User
go4par wrote:Also, neither Comcast nor Net Gear say they can adjust my modem/router clock and thus one hour behind. I don't see any clock settings incl. DLSavings time.
On the Orbi web interface, Advanced Tab->Administration->NTP Settings is where the users has a choice of which NTP server to use and whether to follow Daylight Saving Time.
- go4parJul 06, 2019Aspirant
Thanks for taking the time to reply. I do not have an ORBI. (when I hit reply here it asks which device I have (c6250/AC1600 C/M/R). It seems that does not show up. (?). I also looked on the MYNetGear page and Comcast page. I'll call comcast again (NG always wants more $$ to get support). Regards
go4par wrote:My PC gets them also but it is the Router's DNS (75.75.75.75) attacking the IP/Mask.
When I do a "nslookup" on 75.75.75.75 it comes up as Comcast's DNS server. If Comcast is the ISP, then I would expect to get packets from 75.75.75.75 There is a way to check, on the Advanced Tab->Internet Setup, what does it show for DNS servers?
It has been a long time since I did a "factory reset" on my Orbi, but my memory is that the only box checked on the WAN Setup was the Disable IGMP Proxy.
- fdannaJul 05, 2019StarMy solution was to send the Orbi back to Amazon and get something else (I’m trying the google system).
