Richar51
Dec 26, 2019Aspirant
Disable Red Mute LED
Is there a way to disable the red LED when you mute the voice assistant, in my case Alexa? Reason being, the mic is too sensitive and I have Alexa devices competing for my attention two rooms away. I ...
Dec 26, 2019Guru - Experienced User
You can change the echo's "wake word" to individualize the devices.
That's what I've done with my devices that are close enough to interact with each other.
Richar51
Thank you. I do that for other devices as well, but unfortunately Orbi does not currently allow you to change the wake word. Please let me know if anybody understands otherwise.
Thank you again !
Thank you again !
- plemansDec 26, 2019Guru - Experienced User
Right but if you leave the orbi as alexa and change all the others to echo, sweet cheeks, etc.....then you should be good.
- Richar51Dec 26, 2019AspirantGot ya. It’s a viable work around to what I would think would be a standard feature. I’ll give it some thought. Appreciate it !
