Richar51
Dec 26, 2019Aspirant
Disable Red Mute LED
Is there a way to disable the red LED when you mute the voice assistant, in my case Alexa? Reason being, the mic is too sensitive and I have Alexa devices competing for my attention two rooms away. I ...
Richar51
Thank you. I do that for other devices as well, but unfortunately Orbi does not currently allow you to change the wake word. Please let me know if anybody understands otherwise.
Thank you again !
Thank you again !
Dec 26, 2019Guru - Experienced User
Right but if you leave the orbi as alexa and change all the others to echo, sweet cheeks, etc.....then you should be good.
- Richar51Dec 26, 2019AspirantGot ya. It’s a viable work around to what I would think would be a standard feature. I’ll give it some thought. Appreciate it !
