bhenry
Apr 25, 2020Tutor
disable wireless backplane to avoid high frequency channels
I first got the Orbi mesh because our house did not have ethernet pulled to different parts of the house and i used the wireless backplane. We are in a new house now with wired cat 6 to several poi...
Apr 25, 2020Guru - Experienced User
The xbox conrollers and headsets don't use 5Ghz frequencies. My two Orbis don't crash my controller. Headset is wired for me though.
- bhenryApr 25, 2020Tutor
Sorry I may have mis-spoke it is only the Wireless Headset on his Xbox One that is the issue and it is apparently the Xbox One Wifi Direct protocal that uses 5GHZ on the One series.
5G wifi can interfere with your Xbox one controller. Try changing the default channel of your wifi router until the issue clears up. If you have the Astro A50s, avoid the higher channels. ... The Xbox 360 uses 2.4GHz RF for its wireless protocol for controllers and the Xbox One uses 5GHz RF.
https://www.reddit.com/r/xboxone/comments/a0vfvc/does_the_xbox_one_controller_have_a_5ghz/
