NG_LostMyAcct
Nov 29, 2018Tutor
Disabled my Mesh Network Due to No Orbi 5GHz Backhaul to Satellite
Hi - I have a serious problem where my Orbi backhaul connection to my RBS50 Satellite only appears to be connecting at 2.4 GHz which is restricting the speed of any devices connected to the satellite...
NG_LostMyAcct
Nov 30, 2018Tutor
Hi, FURRYe38 - I have tried setting Daisy Chain to both Enabled and Disabled, but there was no noticeable difference to the 5G Backhaul connection. :smileysad:
Nov 30, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
- NG_LostMyAcctNov 30, 2018Tutor
FURRYe38 - They were about 40 - 50 feet apart normally. Not a lot of heavy materials in the way obstructing the router/satellite, just one stucco & wood wall in between.
I brought the satellite into the same room as the router, so now around 15 feet apart without obstructions. I also tried changing channels as you suggested (2.4 GHz at Channel 1, 5 GHz at Channel 44).
No differences seen - the 5 GHz backhaul channel is still grayed-out on the satellite.
- ekhalilNov 30, 2018Master
Can you please make a wifi scan. Can you see the “hidden” wifi networks from your router’s and satellite’s backhaul? Those networks have no SSID and using high 5GHz channels (usually 108 or 124). You see one such network for the router’s MAC and another for the Satellite’s. There are also similar hidden networks for the 2.4GHz backhaul channel but thone will be the same channel used for the fronthaul.
Can you see other networks broadcasting on the same 5GHz channels as the ones used for backhaul?
Hi, ekhalil -
I don't see any 5GHz hidden WiFi channels active in the high 5GHz channels from my router. I do see (2) Ch 48 broadcasts listed for my main WiFi + (2) Ch 48 broadcasts listed for my Guest network, so (4) Ch 48 broadcasts total. Maybe something to do with my WiFI scanning app?
I can occasionally see my neighbor's Zyxel router broadcasting at channel 149, bu never my router..
