ND06
Sep 09, 2020Aspirant
Disabling 5ghz on Orbi using the app
Good morning I need to suspend my 5 ghz WiFi in order to connect some devices to 2.4 . I have seen other threads about “ advanced settings and disabling SSID “ however I can’t seem to do this from the...
schumaku
Sep 09, 2020Guru - Experienced User
Non-standard operations procedure. Use the Web UI if documented.
