ND06
Sep 09, 2020Aspirant
Disabling 5ghz on Orbi using the app
Good morning I need to suspend my 5 ghz WiFi in order to connect some devices to 2.4 . I have seen other threads about “ advanced settings and disabling SSID “ however I can’t seem to do this from the...
ND06
Sep 10, 2020Aspirant
My wireless alarm platform doesn’t recognise my router . I have seen a previous post here recommending suspending the 5ghz band to allow it to connect
Sep 10, 2020Guru - Experienced User
Try the afore mentioned process to see if this helps. Make contact with the mfr of this security product for additional help and information.
