ND06
Sep 09, 2020Aspirant
Disabling 5ghz on Orbi using the app
Good morning I need to suspend my 5 ghz WiFi in order to connect some devices to 2.4 . I have seen other threads about “ advanced settings and disabling SSID “ however I can’t seem to do this from the...
scoboo
Mar 07, 2021Guide
It appears that the UI has changed since you posted this recommendation.
A user should be able to click the "Basic" tab
Click the "Wireless" side tab
Then uncheck "Enable 5G"
Please see this screenshot:
CrimpOn
Mar 07, 2021Guru - Experienced User
Inline images do not appear until approved by a forum moderator.
Images "attached" using the Browse button in the lower left are available immediately.
(and, no, I have no clue why the forum thinks JPG and PDF images are so dangerous.)
