mbreksop
Nov 01, 2021Star
Disabling Auto Update (Force Update) firmware version 2.7.3.22 for Orbi 3000 (RBR, RBS and RBK 50)
Hi, It seems like Netgear now forces a new EULA requiring Auto Firmware Upgrade for all Orbi Routers, unfortunately for our RBR/S/K 50, the new 2.7.3.22 is buggy, and sometimes drop connections b...
- Nov 01, 2021
And by the way, do above steps on every devices (routers and satellites too).
Remember after enable root, you can telnet using 'root' account without password. Highly advice, to change the root password immediately. Also once you are done, please ensure you disable the telnet access.
Hopefully this works, any ideas, please let me know.
