mbreksop
Nov 01, 2021Star
Disabling Auto Update (Force Update) firmware version 2.7.3.22 for Orbi 3000 (RBR, RBS and RBK 50)
Hi, It seems like Netgear now forces a new EULA requiring Auto Firmware Upgrade for all Orbi Routers, unfortunately for our RBR/S/K 50, the new 2.7.3.22 is buggy, and sometimes drop connections b...
- Nov 01, 2021
And by the way, do above steps on every devices (routers and satellites too).
Remember after enable root, you can telnet using 'root' account without password. Highly advice, to change the root password immediately. Also once you are done, please ensure you disable the telnet access.
Hopefully this works, any ideas, please let me know.
mbreksop
Nov 03, 2021Star
Free Account...
And yes it works, i just checked few minutes ago.
Both Router and Satellites shows 'Update Failed'.
Now I love my Orbi again.... ;-)
CrimpOn
Nov 03, 2021Guru - Experienced User
My "Bag of Tricks" is now almost complete! Thanks.
The key to your fix is getting something written into that "read only" memory that is used to create the working image when the Orbi boots.
All of the previous gimmicks, such as setting paramters and the firmware_version hack do not survive a reboot.
Hmmmm. Wonder if it is possible to log in as root and get access to that protected space? Something to look into.
