carfnann
Oct 02, 2018Aspirant
Disabling DHCP
Hello,
I installed my kit Orbi RBK23 (with AC2200) on my current network.
My current router is already doing DHCP work and I want to keep that.
I changed in the LAN configuration and disable the Orbi DHCP, but unfortunately even after this disabeled, all devices connecting to the Wifi has an IP address in 10.0.0.X while my network is 192.168.X.X
I tried the restart but nothing helps ...
I prefer not to swicht Orbi in AP mode because in this case I lose the parental control features Circle.
Can you help me?
Thank you
1 Reply
Sort By
If your using a different router or DHCP service, then you'll either need to keep DHCP running on the Orbi as well to keep parental controls enabled and be able to use them. Or use AP mode and use parental controls on the other router.
